How to adjust the width of a point multiple times
kenneth0322
Hi. I am a beginner.
I understand myself that this is a stupid question, but I'm getting confused, so can someone please help me?
I have created a point using the addpoint function. I would like to change the interval of it multiple times, what should I do?
For example, I want 1~23 points to be spaced 1 meter apart, 24~86 points to be spaced 2.5 meters apart, 87~123 points to be spaced 5 meters apart, and so on. And those points are in a straight line.
If anyone can help me with this, please let me know.
Sorry if my English is bad. Thanks.
Hi Ken,
set up a line with zero length, initialize transforms using rig doctor, and shift point positions in a rig wrangle:
int class = 0;
class += i@ptnum > 23;
class += i@ptnum > 87;
float spacing[] = array(1.0, 2.5, 5.0);
pretranslate(4@localtransform, set(0.0, 0.0, spacing[class]));
spacing_dots.hiplc
  • Thanks 1
I like these two lines :)
I have to remember the trick
I've just converted the rig wrangle into a classic detail wrangle. May be more "classical" way.
@konstantin magnus
by the way, why do you use pretransform rather than transform (who seam to also work) ?
Classical vex way.hiplc
Edited by flcc
  • Thanks 1
  • 2 weeks later...
Ok, then maybe this allows for testing a bit more:
int partition[] = array(12, 38);
float spacing[] = array(1.5, 2.5, 5.0);
float rotation[] = array(-3, 2, 18);
int class = 0;
foreach(int part; partition){
    class += i@ptnum > part;
rotate(4@localtransform, radians(rotation[class]), {1,0,0});
i@class = class;
spacing_roating_dots.hiplc
