RT_SD Posted January 18, 2022 Share Posted January 18, 2022 I need to reuse the constraint polylines from an RBD sim after the simulation is done (to create visible geomerty for rendering) but the only geo I can find is the constraint's initial state and the rbd geometry itself. It doesn't look like the polylines are kept at all. How can I reconstruct the simulated constraint lines between rbd pieces to use downstream in the network? Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted January 19, 2022 Share Posted January 19, 2022 23 hours ago, RT_SD said: I need to reuse the constraint polylines from an RBD sim after the simulation is done (to create visible geomerty for rendering) but the only geo I can find is the constraint's initial state and the rbd geometry itself. It doesn't look like the polylines are kept at all. How can I reconstruct the simulated constraint lines between rbd pieces to use downstream in the network? Hi, read this 1 Quote Link to comment Share on other sites More sharing options...
RT_SD Posted January 19, 2022 Author Share Posted January 19, 2022 Thanks. That worked! Quote Link to comment Share on other sites More sharing options...
