Consulting on fibre/wire systems
xarthur
I'm a bit new to Houdini and am trying to simulate a "fill power" test of the down feathers.
Fill Power Test
I can do this for a few spheres with the FEM system. However, this is slow and won't show the fibres...
Would it be possible to do it in a fibre-like way?
The down cluster looks like this: down cluster
Each unit could be as simple as "a small core with many curves grown on it".
I tried vellum hair, but it seems hard to attach the hair in a stiff way and have high stiffness. Also, I cannot make curved hair work, only straight lines.
I'm considering the "wire" system at the moment.
But most of the tutorials I can find online are for simulating ropes... I guess what I need is something similar to a "sphere with tree branches grown in all directions", and simulate a compression test with a lot of these spheres...
My question is, is Houdini the right tool for something like this, and, what should be a good way to approach it?
Could you just do a ton of 3x3 polys with random bent shape, vellum, squash em, texture with a cluster texture? :P Or you want them to be completely volumetric?  Could try the polygon "Asterisk" like in games, with a fuzz cluster texture and it would sort of have depth until squashing....
Simulating every strand etc would be a bit mad but doable if you really needed vellum hairs.
Edited by HM_2020
Unfortunately not.
I'd like to test out the how different parameters (fibre length, number, etc.) will affect the results. So no volumetric.
I don't need too many strands actually, FEM rod module may also do that, but the material available for rod-based FEM in Houdini is very limited. And might be slow.
