create densier points area
4 hours ago, gangland said:
Hey guys
i using points replicate to create an densier points area with an falloff by the single points.
i create an float attribute in the points, going from 0.0 to 1.0. then used the @val in the uniform scale parameters in point replicate sop.
it just return 0 =x
please help me
falloff_by_atribute.hip
Hello,
you want to create @pscale before Point Replicate sop with value equal to your @val multiplied by some scale factor. Or you can using @pscale directly instead of @val.
