Rig attribute vop- transform from path
Phaidonas
Hello all, I try to make a centipede rig that is based on this tutorial from side fx
https://www.sidefx.com/gallery/kinefx-spider/
But rather than having only one point for the hip, I have a curve that I copied the pair of legs, so I have multiple hips, everything works perfect except the animation part that he passes the rig from a rig attribute node and then from a transform from path to set point transform, I tried for each loops, I tried wildcards, I tried to run the vop in points and detail, but nothing seems to work for multiple pair of legs, is there a way to pass to set point transform each one of the legs?
Thanks a lot
