Phaidonas Posted February 14, 2022 Share Posted February 14, 2022 Hello all, I try to make a centipede rig that is based on this tutorial from side fx https://www.sidefx.com/gallery/kinefx-spider/ But rather than having only one point for the hip, I have a curve that I copied the pair of legs, so I have multiple hips, everything works perfect except the animation part that he passes the rig from a rig attribute node and then from a transform from path to set point transform, I tried for each loops, I tried wildcards, I tried to run the vop in points and detail, but nothing seems to work for multiple pair of legs, is there a way to pass to set point transform each one of the legs? Thanks a lot Quote Link to comment Share on other sites More sharing options...
Librarian Posted February 15, 2022 Share Posted February 15, 2022 @Phaidonas Post file Please with your setup, I have some setup on caterpillar ... production file From Abracadabra ..they posted by Mistake ..can't post sorry. Nice tricks inside ..maybe we can manage something Quote Link to comment Share on other sites More sharing options...
Phaidonas Posted February 15, 2022 Author Share Posted February 15, 2022 hey, thank you, here is the file, I made it somehow to fix the animation, now the problem is the ik setup. centipede_rig.hipFetching info... Quote Link to comment Share on other sites More sharing options...
