Karma in SOP with instanced objects
I have an issue with Karma and instances. I use Karma as a render node in the SOP context in a ROP node (so not in Solaris). The instances I set are showing in the viewport, working properly in Mantra, but not in Karma.
Here is a simple example:
This is what I get in Mantra:
But unfortunately Karma shows no instances:
Is there a special way instances can be rendered out with Karma?
I hope someone can explain wht I missed.
Thank you in advance.
PS: sample file is attached.
karma_instance_issue.hipnc
