sessionbeer Posted March 8, 2022 Share Posted March 8, 2022 Is something this possible in Houdini using a gradient ramp on a grid? 3C1CAE32-2A7D-411E-BB6C-0BDD58CCCAFF.webp Quote Link to comment Share on other sites More sharing options...
sessionbeer Posted March 8, 2022 Author Share Posted March 8, 2022 Something like this Quote Link to comment Share on other sites More sharing options...
Librarian Posted March 8, 2022 Share Posted March 8, 2022 (edited) @sessionbeer You only interested in VOP solution or? I like Topic . theory li2 li1 https://www.sidefx.com/docs/houdini/ref/utils/iquantize.html Edited March 8, 2022 by Librarian Quote Link to comment Share on other sites More sharing options...
sessionbeer Posted March 8, 2022 Author Share Posted March 8, 2022 45 minutes ago, Librarian said: @sessionbeer You only interested in VOP solution or? I like Topic . theory li2 li1 https://www.sidefx.com/docs/houdini/ref/utils/iquantize.html Vex or VOP would be great to learn from Quote Link to comment Share on other sites More sharing options...
sessionbeer Posted March 8, 2022 Author Share Posted March 8, 2022 (edited) I've tried to convert this to vex but stuck on the #define functions https://www.shadertoy.com/view/7sfXDn I'm not sure vex is capable of looping through the functions like this? float myscale = 0.4; float Bayer2(vector2 a) { a = floor(a); return frac(a.x / 2.0 + a.y * a.y * .75); } #define Bayer4(a) (Bayer2 (.5 *(a)) * .25 + Bayer2(a)) #define Bayer8(a) (Bayer4 (.5 *(a)) * .25 + Bayer2(a)) #define Bayer16(a) (Bayer8 (.5 *(a)) * .25 + Bayer2(a)) #define Bayer32(a) (Bayer16(.5 *(a)) * .25 + Bayer2(a)) #define Bayer64(a) (Bayer32(.5 *(a)) * .25 + Bayer2(a)) float dithering = (Bayer8(@uv * 0.25) * 2.0 - 1.0) * 0.5; vector2 uv = set(@P.x, @P.z) / myscale; @uv.x += dithering; @Cd = @uv.x; Edited March 8, 2022 by sessionbeer Quote Link to comment Share on other sites More sharing options...
Alain2131 Posted March 9, 2022 Share Posted March 9, 2022 (edited) Huh, the result is pretty neat. You're basically there, but with a few issues. Sorry if I ramble a bit, I tend to be quite lengthy in my explanations. The error message from your code says "No matching function for float Bayer2(float). Candidates are: float Bayer2(vector2 &)" This shows that VEX has an issue with a variable type. If we comment everything and leave only this float Bayer2(vector2 a) { a = floor(a); return frac(a.x / 2.0 + a.y * a.y * .75); } float dithering = (Bayer2(@uv * 0.25) * 2.0 - 1.0) * 0.5; The same issue occurs. But that code doesn't do anything with #define and whatnot. So there's an issue with how we call Bayer2. Basically, VEX doesn't like "@uv". Bayer2 takes a vector2. But how are we passing @uv ? Is it a vector3, or a float ? Either way that's a problem, we specifically need a vector2. The fix is to tell VEX the type we want, with a "u" for vector2. float Bayer2(vector2 a) { a = floor(a); return frac(a.x / 2.0 + a.y * a.y * .75); } float dithering = (Bayer2(u@uv * 0.25) * 2.0 - 1.0) * 0.5; Great. Now we have a different error. "Error: Read-only expression given for read/write parameter." This is because we are trying to modify the variable "a" in the Bayer2 function. VEX doesn't like that for some reasons. The fix is simple enough - make a temporary variable (and replace the subsequent references of a). float Bayer2(vector2 a) { vector2 b = floor(a); return frac(b.x / 2.0 + b.y * b.y * .75); } float dithering = (Bayer2(u@uv * 0.25) * 2.0 - 1.0) * 0.5; Cool, so we are now error-free. Let's bring back the #defines and use one of them instead of Bayer2. float Bayer2(vector2 a) { vector2 b = floor(a); return frac(a.x / 2.0 + a.y * a.y * .75); } #define Bayer4(a) (Bayer2 (.5 *(a)) * .25 + Bayer2(a)) #define Bayer8(a) (Bayer4 (.5 *(a)) * .25 + Bayer2(a)) #define Bayer16(a) (Bayer8 (.5 *(a)) * .25 + Bayer2(a)) #define Bayer32(a) (Bayer16(.5 *(a)) * .25 + Bayer2(a)) #define Bayer64(a) (Bayer32(.5 *(a)) * .25 + Bayer2(a)) float dithering = (Bayer8(u@uv * 0.25) * 2.0 - 1.0) * 0.5; Alright, no error, looking good. Now for the last part of your code.. float myscale = 0.4; float Bayer2(vector2 a) { vector2 b = floor(a); return frac(a.x / 2.0 + a.y * a.y * .75); } #define Bayer4(a) (Bayer2 (.5 *(a)) * .25 + Bayer2(a)) #define Bayer8(a) (Bayer4 (.5 *(a)) * .25 + Bayer2(a)) #define Bayer16(a) (Bayer8 (.5 *(a)) * .25 + Bayer2(a)) #define Bayer32(a) (Bayer16(.5 *(a)) * .25 + Bayer2(a)) #define Bayer64(a) (Bayer32(.5 *(a)) * .25 + Bayer2(a)) float dithering = (Bayer8(u@uv * 0.25) * 2.0 - 1.0) * 0.5; vector2 uv = set(@P.x, @P.z) / myscale; @uv.x += dithering; @Cd = @uv.x; Cool, no error again, and something happens in the viewport.. Something that is evidently not Bayer Dithering. Hmm, alright, what's up with that. Now that you are unblocked, if you want to figure it out by yourself, now's the time to do it. Alright ? Cool. Here's the solution. In your code, you assumed that "fragCoord" from the HLSL code was the same as UVs. That is slightly incorrect. In shadertoy, if you map fragColor to fragCoord, you'll find out that fragCoord actually represents the canvas size in pixel. In my case, max(fragCoord) == (1200, 675) (those numbers were taken from the information at the bottom-left of the canvas) To test that out, I wrote the following in shadertoy, and got the classic UV black, red, green, orange and yellow result. fragColor = vec4(fragCoord.x / 1200.0, fragCoord.y / 675.0, 0, 0); (actually I started with fragCoord.x only, saw that it was SUUUPER red, then tried dividing by 255, saw the gradient appearing in only a small portion of the canvas, then tried dividing with the X resolution, and got a full gradient in red, and thus I understood what I just mentioned) SO ANYWAY All of that is to say that you have to multiply the u@uv by the resolution of your grid. Here's what I added vector2 fragCoord = u@uv * set(ch("../grid1/rows"), ch("../grid1/cols")); float dithering = (Bayer8(fragCoord * 0.25) * 2.0 - 1.0) * 0.5; We now have a different result, but still a broken one. Hooray. Let's focus on the last three lines, one after the other. vector2 uv = set(@P.x, @P.z) / myscale; That is wrong. The HLSL reference is Quote vec2 uv = fragCoord / iResolution.xy; We know that fragCoord is u@uv * resolution And that line is basically doing (u@uv * resolution) / resolution. In our case, this line is simply vector2 uv = u@uv; But let's add the scale parameter you had vector2 uv = u@uv / chf("scale"); Next line @uv.x += dithering; The fix is simple enough, we want to modify the uv variable, and not the uv attribute. uv.x += dithering; Final line @uv.x += dithering; Same thing, we want to use the uv variable. Also, the HLSL does a comparison Quote fragColor = vec4(uv.x < 0.5); So let's do that @Cd = uv.x < 0.5; All put together, here's the final code float Bayer2(vector2 a) { vector2 b = floor(a); return frac(b.x / 2.0 + b.y * b.y * 0.75); } #define Bayer4(a) (Bayer2 (.5 *(a)) * .25 + Bayer2(a)) #define Bayer8(a) (Bayer4 (.5 *(a)) * .25 + Bayer2(a)) #define Bayer16(a) (Bayer8 (.5 *(a)) * .25 + Bayer2(a)) #define Bayer32(a) (Bayer16(.5 *(a)) * .25 + Bayer2(a)) #define Bayer64(a) (Bayer32(.5 *(a)) * .25 + Bayer2(a)) vector2 fragCoord = u@uv * set(ch("../grid1/rows"), ch("../grid1/cols")); float dithering = (Bayer8(fragCoord * 0.25) * 2.0 - 1.0) * 0.5; vector2 uv = u@uv / chf("scale"); uv.x += dithering; @Cd = uv.x < 0.5; So yeah, sorry for the gigantic answer, it could have been only the last snippet, but I hope this is more useful to you than just the answer. Cheers ! Edited March 9, 2022 by Alain2131 2 Quote Link to comment Share on other sites More sharing options...
Librarian Posted March 9, 2022 Share Posted March 9, 2022 @Alain2131 @sessionbeer hm I don't see anything on my view port. Please someone post a scene Quote Link to comment Share on other sites More sharing options...
Librarian Posted March 9, 2022 Share Posted March 9, 2022 ahaaaa I get it iii.hiplc Quote Link to comment Share on other sites More sharing options...
sessionbeer Posted March 9, 2022 Author Share Posted March 9, 2022 @Alain2131 Thank you for your detailed reply, extremely grateful for how you broke everything down! You should become a teacher Quote Link to comment Share on other sites More sharing options...
