attribute access in parameters
saca
hi,
i have simple wondering with attribute access for parameters input.
here is "dist" attribute from distanceAlongGeo(SOP).
on PolyWire(SOP)/radius, i can access with "@dist".
on Mountain(SOP)/height, i cannot access with "@dist".
by other way, point() expression,
on PolyWire(SOP)/radius, i can access point(opinputpath(".",0),$PT,"dist",0) too.
on Mountain(SOP)/height, i cannot access point(opinputpath(".",0),$PT,"dist",0) neither.
what reason these difference?
thanks.
falloff_distance_v001_002.hip
Edited by saca
@saca attribute rename Mask(or dist) to "height" than you no need to have @ in parameter in Mountain SOP....
if you open(allow editing mountain  Sop you goona see inside VOP why ...you can use falloff node with Blend function also and rest
float blend = point(0, chs("../attrib"), @ptnum);
@P = lerp(@P, point(1, "P", @ptnum), blend);
Edited by Librarian
