Camera follow the path
wyy
Try using the Follow Path button on the Animation shelf tool. The shelf may be turned off by default. Click on the + move down to Shelves and click the check box to turn it on.
Read the messages on the bottom of the 3D viewport to know which object to select next. Make sure your mouse is inside the 3D viewport when you press ENTER after each step. It sounds complicated, but it's not.
  • Make a new camera and select it.
  • Click the shelf tool and read the bottom of the screen.
  • Select the path, press enter, then select your look-at null and press enter.
Edited by Atom
21 hours ago, Atom said:
Try using the Follow Path button on the Animation shelf tool. She shelf may be turned off by default. Click on the + move down to Shelves and click the check box to turn it on.
Thank you!
