[TOP/PDG] A Python script to get workitem attributes causes an error on ROPGeometry TOP
willlinks
Hi There,
I'm trying to grab all attributes on the current work item in TOP and assign them to points in SOP.
I wrote a python script and it works fine in SOP lively but I'm getting an error or crush when I kick off ROP Geometry Output TOP.
I used python approach because I have several attributes to transfer and the attributes can be changed in the future so I'd like to avoid using @xxxx with hardcoded attribute names in SOP.
It would be great to have some suggestions. Thanks you ~
Edited by willlinks
Here are my updated simplified hip and script.
import pdg
node = hou.pwd()
geo = node.geometry()
# Setting target attributes
top_node = hou.node("/obj/topnet1/partition_items")
top_node.cookWorkItems()
target_work_items = top_node.getPDGNode().workItems
target_attrib_names = target_work_items[0].attribNames()
# Current work item
work_item = pdg.workItem()
attrib_names = work_item.attribNames()
# Make point attributes
for attr in attrib_names:
    if attr in target_attrib_names:
        val = work_item.attribArray(attr)[0]
        geo.addAttrib(hou.attribType.Point, attr, val)
# Set point attribute values
i = 0
for point in geo.points():
            vals = work_item.attribArray(attr)
            if len(vals)>1:
                val = vals[i]
                point.setAttribValue(attr, val)
    i += 1
Hip File : pdg_attributes.zip
I see the error below but I don't see the python node erroring out...
