Relative Flatness
i am trying to make a mask based on the relative flatness of my mesh or relative curvature? i am not sure how to put it.
i have a rock with bumps everywhere obviously but you can clearly see areas where in general it is flat although there are small bumps, you can distinguish relatively flat surfaces by eye.
i tried generating the curvature map and then blurring it but the results are not that good. They are soft after the blur and not precise.
the other thing i tried is clustering by normal -6 clusters- for a box like projection if you will. but the problem with clustering is yuo have to decide the number of clusters.
i would prefer a threshold of normal similarity. thats what i will try to do next
