DonRomano Posted May 15, 2022 Share Posted May 15, 2022 Hello everyone, I'm using hython to run a bunch of files on remote computers and sometimes the network shuts down for a few seconds, causing the "job" to be suspended undefinitely, the only solution being killing the process. Then in the stdout I have this message appearing : Cannot access the OTL source: //Path/To/Some/file.hda for operator type: somehda “Save & Quit” will save the hip file and quit the session “Discard & Quit” will quit the session without saving the hip file “Retry” will attempt again to refresh the OTL definition from the same file location “Embed” will try to use an alternative definition among already loaded OTLs, and if no suitable definition is found, it will create a hollow, embedded fallback OTL which allows you to continue working with the hip file “Refresh OTLs” will reload OTLs found in the search path and try to use them for the operator definition “Load OTL” will present a file chooser to specify an explicit OTL location where the operator definition can be found 0: “Save & Quit” 1: “Discard & Quit” 2: Retry 3: Embed 4: “Refresh OTLs” 5: “Load OTL” Anyone knows if there is a way to force hython to one option ? It's a bit annoying... Quote Link to comment Share on other sites More sharing options...
