(SOLVED) Deform with particles or in SOP in X and Z directione
  • Librarian changed the title to (SOLVED) Deform with particles or in SOP in X and Z directione
i found a way Yupiiii:wub:
s@name = sprintf("piece_%d", i@iy);
// get actors names
string name = sprintf(s@name);
// split actors name up into array using space as delimiter
string actorSplit[] = split(name, " ");
// join array with underscores to create the group name
string groupName = join(actorSplit, "_");
// set group name
setpointgroup(0, groupName, @ptnum, 1, "set");
float k = 2 *noise(@Time);
@P *= set(1/sqrt(k),k,1/sqrt(k));
@P += @P *flownoise(@P*3,@Time);
i[]@pCaptPts = pcfind(1,"P",@P,1e15,8);
float r = 1.1 *distance(point(1,"P",@pCaptPts[-1]),@P);
vector delta;
float totalweight_cpt;
matrix3 totalxform_cpt;
foreach(int cpt;@pCaptPts){
    vector oldcenter = point(1,"P",cpt);//Rest_POint_latice
    vector newcenter= point(2,"P",cpt);//deformed_point_latice
    matrix3 xform_cpt = 1;
    int n[] = neighbours(1,cpt);
    //int n[] = neighbours(2,cpt);
    matrix3 totalxform = 0;
    float totalweight = 0;
        if (len(n)>1){
        vector lastdp,lastrestdp;
        for (int i;i<len(n);i++){
        if(i==0){
        lastdp = point(1,"P",n[-1])-oldcenter;
        lastrestdp = point(2,"P",n[-1])-newcenter;
        vector dp = cross(dp,lastdp);
        vector restdp = cross(restdp,lastrestdp);
        vector up = cross(dp,lastdp);
        vector restup = cross(restdp,lastrestdp);
        float w = sqrt(length(up)*length(restup));
        matrix3 restxform = maketransform(normalize(restdp),normalize(restup));
        matrix3 xform = maketransform(normalize(dp),normalize(up));
        totalxform += w*invert(xform)*restxform;
        totalweight += w;
        lastrestdp = restdp;
        lastdp = dp;
        if(totalweight!=0){
            totalxform/= totalweight;
            if(chi("rigidprijection"))
            totalxform = polardecomp(totalxform);
            xform_cpt = totalxform;
float dist = distance(oldcenter,@P);
float weight = pow(1-pow(dist/r,2),2);
vector diff = point(2,"P",cpt)-oldcenter;
vector newp = @P;
newp -= oldcenter;
newp *= xform_cpt;
newp += oldcenter;
newp += diff;
delta += weight*(newp-@P);
totalweight_cpt += weight;
totalxform_cpt += xform_cpt*weight;
delta /= totalweight_cpt;
@P += delta;
