Activate FLIP by Attribute
jamesearnest244
I have a FLIP source, and I'd like to control which particles get simulated by using a group - i.e. create a Group node with a bounding sphere and animate its size, so that only points inside that group get simulated.
I have the basic setup, using a POP Group node with Preserve Group checked on. Then I set @v to {0,0,0} on all points outside that group. It kind of works, but the boundary is kind of soft, and points from outside keep creeping in and getting simulated. Maybe there's something else I could use? Something similar to the @active attribute in Bullet?
Hip file attached.
Thanks for any suggestions!
Activate By Attribute.hip
