Houdini: OpenCL Error clEnqueueNDRangeKernel (-52)
Soyouz3
Hello Houdini Wizards!
I'm currently facing an issue with openCL.
I'm working on a tool using openCL, being pretty happy with it, I was testing it after a vellum simulation, everything was working well, no errors at all.
I shut down my computer for the night, and when I come back this morning I get this error.
The issue appears even doing a simple deformation as you can see on the image
Here is few things that I checked before writing this thread:
            - The preferences of the openCL seems correct, changing it to CPU doesn't fix the issue.
            - my houdini.env file is set with the following argument:
                                   HOUDINI_OCL_DEVICETYPE=GPU
                                   HOUDINI_OCL_VENDOR=NVIDIA Corporation
            - My graphic drivers are up to date (running with NVIDIA GeForce RTX2060).
            - I tried to revert to houdini 19 to see if it would fix it but I still get the error.
Here is the issue from the console:
                  OpenCL Exception: clEnqueueNDRangeKernel (-52)OpenCL Context error: CL_INVALID_KERNEL_ARGS error executing CL_COMMAND_NDRANGE_KERNEL on NVIDIA GeForce RTX 2060 (Device 0).
Did anyone faced that issue working with openCL previously or found a solution?
Cheers!
