JJ FX Posted September 1, 2022 Share Posted September 1, 2022 Hi, How would you transfer edge groups using subdivision? I can't figure it out... Quote Link to comment Share on other sites More sharing options...
JJ FX Posted September 1, 2022 Author Share Posted September 1, 2022 So here's the solution: before subdiv > uvflatten (using the edge group) > subdivide > splituvseams > group (edge, unshared edges) 1 Quote Link to comment Share on other sites More sharing options...
Benyee Posted September 2, 2022 Share Posted September 2, 2022 (edited) that's tricky, and several weeks ago I used another approach for maintaining edge group on subdivided geo, hope there are some useful informations for you https://www.sidefx.com/forum/topic/85561/ cut_plane_with_edges_v2.hip Edited September 3, 2022 by Benyee 1 Quote Link to comment Share on other sites More sharing options...
animatrix Posted September 3, 2022 Share Posted September 3, 2022 Hi, You can update your edge groups automatically using VEX (Detail Wrangle), but you will pay performance penalty for very high res geometry that has very large edge groups: string edgegroups [ ] = split ( chs("edgegroups"), " " ); foreach ( string edgegroup; edgegroups ) { int pts [ ] = expandedgegroup ( 1, edgegroup ); int count = len ( pts ); for ( int i = 0; i < count; i += 2 ) { int pt0 = pts [ i ]; int pt1 = pts [ i + 1 ]; int pts0 [ ] = neighbours ( 0, pt0 ); int pts1 [ ] = neighbours ( 0, pt1 ); int sharedpt = -1; foreach ( int pt; pts0 ) { if ( find ( pts1, pt ) >= 0 ) { sharedpt = pt; break; } } if ( sharedpt != -1 ) { setedgegroup ( 0, edgegroup, pt0, sharedpt, 1 ); setedgegroup ( 0, edgegroup, pt1, sharedpt, 1 ); } } } Edge group expression: `edgegrouplist(-1)` If you need multiple levels of subdivision, you need to encapsulate the Subdivide and Attribute Wrangle inside a For Each Loop network, as the edges have to be updated at each subdivision. Alternatively you can change the VEX code to walk the edges instead, then it would handle any edge group regardless of the subdivision levels difference between 2 geometries. 2 Quote Link to comment Share on other sites More sharing options...
dandeentremont Posted August 20, 2025 Share Posted August 20, 2025 The simplest way I've been able to do this is by using UV Flatten to split the edge groups into separate islands (I call it uv2 or something to avoid overwriting existing uvs) Then subdivide. THEN use Group From Attribute Boundary, which looks at UVs by default. Change it to your custom uv2 channel. 1 Quote Link to comment Share on other sites More sharing options...
