Vellum Interaction With Rigid Body Objects
liamportz
Hi guys,
I hope you can help me with setting up this vellum inflation scene...
Basically, I have animated a sphere expanding and used the rest blend node inside the vellum solver to inflate the sphere. What I would like to achieve is an interaction where the vellum inflation sim interacts with a rigid body 'plinth' that it is initially sitting on rather than it just being a static collider object. I have tried using the vellum shape match constraint for this behaviour but have found it tends to deform the shape which is not ideal.
Preferably, I would like to know if it is possible to use RBD dynamics inside of a DOP network and have that interact with the inflating vellum sim... The entire sim would also sit inside of a static container too as the plan is to squash the vellum soft body against the walls of the container.
Any help on this would be really appreciated. Thanks!
Vellum_Rigid_Body_Interaction.hiplc
  • 1 year later...
