UG1005 Posted October 30, 2022 Share Posted October 30, 2022 I am copying points generated by a pop network with pre-cached animations. I use the instance node so that the first frame of the animation comes when the point is generated. However, I am unable to render the object I am displaying using instance node. Is there any way to do this? The renderer is using redshift. instance_test.hip Quote Link to comment Share on other sites More sharing options...
Atom Posted October 30, 2022 Share Posted October 30, 2022 You may need to use the @instancefile attribute to reference geometry on disk, rather than @instancepath. Quote Link to comment Share on other sites More sharing options...
