rob3d Posted November 28, 2022 Share Posted November 28, 2022 (edited) Good morning, I am trying to simulate a meteor hitting a building, I am building a constraint network that seems to work (they have the attribute constraint_name) but once I instance them into the dopnetwork>constraintnetwork node it doesn't get this attribute. I am quite amateur with Houdini and I don't know where this could be come from. Can someone help me out with this? Thanks in advance BuildingFracture_v07.hipncFetching info... Edited November 28, 2022 by rob3d Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted November 29, 2022 Share Posted November 29, 2022 Hi, s@constraint_name is a primitive attribute not a point attribute. Change parameter "Run over" to Primitives on the attribwrangle1 sop and try again. 1 Quote Link to comment Share on other sites More sharing options...
rob3d Posted November 29, 2022 Author Share Posted November 29, 2022 Hello Vicvvsh, That solved it, thank you Quote Link to comment Share on other sites More sharing options...
