How to select points or edges only inside and only outside of a circular ring plane
Ikuya
I have recently been doing some environment modeling in Houdini and often create ring-shaped planes, and I would like to know if there is a smart way to select and create groups of points for inside only or outside only. Currently I am using group bounding spheres, but ideally I would like to do it procedurally.
untitled.hipFetching info...
  • 1 month later...
