PwPwPower Posted February 23, 2023 Share Posted February 23, 2023 If I connect a shape match vellum object to a cloth (I use glue constraints), it loses its rigid nature and starts deforming, there's any way to prevent this? Untitled.mp4 Quote Link to comment Share on other sites More sharing options...
Stephen Moroz Posted March 1, 2023 Share Posted March 1, 2023 Hey, did you find any solution to this yet? I'm having the exact same issue currently. The only way I've found to make the shape match object stay rigid is to increase the mass, but then it weights down far too much on the cloth. Quote Link to comment Share on other sites More sharing options...
Benyee Posted March 5, 2023 Share Posted March 5, 2023 For the rigid body, I did some post-process steps in the simple file attached. First, I set some proper parameter values for the vellum constraints to make the rigid body rigid enough. Then for the post-process I used the matrix calculated from original geo and simed geo to transform the original geo. Hope it helps. rigid_shape_attatched_to_cloth.hipFetching info... Quote Link to comment Share on other sites More sharing options...
