panee Posted April 25, 2023 Share Posted April 25, 2023 (edited) Hi Folks this is my first post. I'm new with arnold in houdini, I use to manage mantra. I'm trying to render volumes (an explosion in this case) with arnold but the volumes don't appear in the render view. As you can see in the pic I attached. Volume exists but in the render view has shown with pink cubes (I applied a standard volume to the explosion node) Does anyone know what is appening? Thanks in advantage panee. Edited April 25, 2023 by panee Quote Link to comment Share on other sites More sharing options...
TobyGaines Posted June 17, 2023 Share Posted June 17, 2023 You need to use Arnold shaders - Quote Link to comment Share on other sites More sharing options...
paranoidx Posted December 3, 2024 Share Posted December 3, 2024 assign a shader for that volume through Object node (obj context) -> Render tab -> Material path Or you can assign shader through Material sop node for that volume inside Object Quote Link to comment Share on other sites More sharing options...
