Polyflogg Posted June 13, 2023 Share Posted June 13, 2023 hello! I'm trying to export an Alembic from H19.5 to Unreal. I have a baked mesh sequence of 32 frames that I'm importing as a geometry cache. The problem I'm having is that exporting an alembic via the rop (and file-> export) seems to be dropping the vertex color entirely. Has anyone here had this issue? I'm really trying to avoid the full fluid vertex animation pipeline (because I hate it ) in lieux of geo caches, but I've run into this issue and can't find a way around it. As a way of confirming, I imported my alembic into Blender, and can see that there's also no color attributes there. If I export a single frame of fbx, it's there, but I can't use FBX because it doesn't properly export a mesh sequence from Houdini. As you can see there is no color info (Cd). Thank you! Marc. Quote Link to comment Share on other sites More sharing options...
