plazadelmar Posted July 17, 2023 Share Posted July 17, 2023 At 00:30 sec there is this beautiful particle effect in this video. Any suggestion how this was made? Quote Link to comment Share on other sites More sharing options...
Librarian Posted July 18, 2023 Share Posted July 18, 2023 @plazadelmar Find Yuya Torii on qiita houdini Advent, for growth solver's. For velocity FUN. On twitter you have user "Whitedog" for pyro solver . But you can find here on Forum also . Than on Forum you have how to advect particles with volumes . trick maybe with colors its to use on volume wrangle if you have Cd, temperature and Density fields ,than you can use attribute from volume to transfer color to particles . if(@P.y > 0.1){ f@density = 0; } f@temperature = fit(f@temperature,0,chf("src_max"),0,chf("target_max")); v@Cd = chramp("Cd",f@temperature); Use also switch(in Sop) to change diff colors and enable solver(in Dop) with expression something like $F<8 || ($F>45 && $F<53) || ($F>90 && $F<98) || ($F>135 && $F<143) || ($F>180 && $F<188) || ($F>225 && $F<233) to change different movement of velocity that you have .. in your case with those growth ivy solver's tangentu .That you shift. v@tangentu *= -0.3; //v@tangentu *= 0.3; and when you use volume from attribute(to transfer vel) make in Y direction 3 or 4 copy's of that velocity . Have Fun. 1 Quote Link to comment Share on other sites More sharing options...
Librarian Posted July 19, 2023 Share Posted July 19, 2023 @plazadelmar Check Volume Optical Flow Tutorials. 1 Quote Link to comment Share on other sites More sharing options...
