Bernard Posted April 18, 2007 Share Posted April 18, 2007 Hello, I'm searching for a specific effect: throw out a box of blocks and the blocks forming a square(puzzle)... How do I setup this effect? Many thanks, bern Quote Link to comment Share on other sites More sharing options...
Visual Cortex Lab Posted April 18, 2007 Share Posted April 18, 2007 I'd go for a "reverse" animation .. like you traceSOP the puzzle pattern.. you sop build your pieces.. then (well.. prior the actual pieces modeling) you animate the traced primitives with CHOP or anything else from the "final" state which is instead the first frame of the timeline... confused enought? .. sorry I'm just back from lunch :S I dont have it here but I can post you a HIP file I did (well.. my houdini first mentor did like 7 years ago) long time ago .. pretty straightforward for this. Quote Link to comment Share on other sites More sharing options...
Bernard Posted April 18, 2007 Author Share Posted April 18, 2007 [one' date=Apr 18 2007, 05:14 AM' post='35285]I'd go for a "reverse" animation .. like you traceSOP the puzzle pattern.. you sop build your pieces.. then (well.. prior the actual pieces modeling) you animate the traced primitives with CHOP or anything else from the "final" state which is instead the first frame of the timeline... confused enought? .. sorry I'm just back from lunch :S I dont have it here but I can post you a HIP file I did (well.. my houdini first mentor did like 7 years ago) long time ago .. pretty straightforward for this. Hello Sum][One, That HIP file would be great! Many thanks, bern Quote Link to comment Share on other sites More sharing options...
