TobyGaines Posted August 30, 2023 Share Posted August 30, 2023 I don't see any way to get things from lops back ito the obj context, LOPimport only seems to work for things that are already saved as usd files... Thanks for any insight Quote Link to comment Share on other sites More sharing options...
jiejia Posted August 30, 2023 Share Posted August 30, 2023 LOP Import Object Node can only import USD Transform Data. What you need is probably LOP Import SOP Node. Quote Link to comment Share on other sites More sharing options...
TobyGaines Posted August 30, 2023 Author Share Posted August 30, 2023 (edited) Thanks for the quick response - do you mean the Import SOP node in LOPs? There is no "LOP Import SOP node" as far as I can tell - I'm using 19.5 I don't think that would help me - I need to get stuff back to OBJ Edited August 30, 2023 by TobyGaines Quote Link to comment Share on other sites More sharing options...
Sepu Posted August 30, 2023 Share Posted August 30, 2023 https://www.sidefx.com/docs/houdini/nodes/sop/lopimport.html#:~:text=This node will import the,primitives%2C using a primitive pattern. Quote Link to comment Share on other sites More sharing options...
TobyGaines Posted November 14, 2023 Author Share Posted November 14, 2023 On 8/30/2023 at 4:03 PM, Sepu said: https://www.sidefx.com/docs/houdini/nodes/sop/lopimport.html#:~:text=This node will import the,primitives%2C using a primitive pattern. Nor any lights Quote Link to comment Share on other sites More sharing options...
