how ca i do this ??
jisun
make of those stairs VDB and use this on Pop wrangle (input 2 ) on first points that you want to use)
float volSample = volumesample(1,0,@P);
vector volGrad = normalize(volumegradient(1,0,@P));
@P -= volGrad * volSample;//adjust Position
@v += @force * @Timeinc;//Force to V
@force = 0;//Force to be 0
vector vVertical = volGrad * dot(@v, volGrad);
vector vHorizontal = @v - vVertical;
@v = vHorizontal;
  • Like 3
  On 9/8/2023 at 11:13 AM, Librarian said:
se Stairs VDB를 사용하여 Pop wangle(입력
계단 VDB를 만들고 사용하려는 첫 번째 지점의 Pop wangle(i nput 2)에서 이것을 사용하십시오.
It's hard to understand.
Can I ask you to share the file? Thank you.
