VEX help! check if value has changed, then do something
anbt
Hello,
I would like to translate this into VEX.
for context, on the first frame, @weight is 0 and becomes not 0 at a specific frame 3, but becomes 0 again at frame 4.
I would like the weight values which changed at frame 3 to stay changed. To get impregnated by the value they had at frame 3
if weight==0 then active==0
but if weight==0 && prevF weight!=0 then active=1
I can't make it work!
int specificFrame = 3; // Define the specific frame
if (@Frame == specificFrame) {
    @myStoredValue = @weight; // Store the value of @weight at frame 3
if (@Frame > specificFrame && @myStoredValue != 0) {
    @weight = @myStoredValue; // Use the stored value for subsequent frames if it's not 0
@anbt Just wondering if anything here its Correct  ?? is it working in your Case ?.. :rolleyes:
int prevFrame = @Frame - 1;
if (@Frame == 1) {
    // Initialize a custom attribute "impregnated_weight" on the first frame
    @impregnated_weight = 0;
} else if (@Frame == 3) {
    // Store the current @weight in the custom attribute at frame 3
    @impregnated_weight = @weight;
} else if (@Frame == 4) {
    // Reset the custom attribute to 0 at frame 4
// Use the stored value from frame 3 if available, otherwise use @weight
if (@Frame > 3) {
    @weight = @impregnated_weight;
// Optionally, you can do additional operations on @weight here
// For example, you can multiply it by some factor:
// @weight *= 2;
if (@Frame == 3) {
    if (s@initialized != 1) {
        s@initialized = 1;
        f@storedWeight = @weight;
    if (s@initialized == 1) {
        @weight = f@storedWeight;
if (@Frame == 3 && !@changed) {
    @changed = 1; // Mark this point as changed on frame 3
    @prev_weight = @weight; // Store the weight at frame 3
} else if (@Frame != 3 && @Frame > 3 && @changed) {
    @weight = @prev_weight; // Restore the weight from frame 3 on subsequent frames
so, this seems to make it work, thanks! Not sure yet if it is bomb proof. Only works if I specify the frame number. Will have a look at the rest of your code
I wrote it like that for now.
if (@Frame == 3) {
    @prevF = @weight;
if (@Frame > 3 && @prevF != 0) {
    @weight = @prevF;
f@prevF = @prevF;
if (@prevF==0) {
    i@active=0;
    } else if (@prevF!=0) {
        i@active=1;
