Adding noise to custom velocity field
Hello there.
Having a velocity field based on some curves but would like to break up the pattern a bit(second picture). When adjusting v the whole
position is getting offsetted allthough i only want to change/add a noise pattern. Or would you maybe use a particle sim with some trails for a vel field like this?
thanks in advance!
Vel_Field.hiplc
