Mjag07 Posted November 21, 2023 Share Posted November 21, 2023 It's been a while since Im been doing any RBDs, But using the old dops method. I have a question can I hook up more than one sop solver into the presim connection to add velocity to certain times? IE Breaking areas on the object up in parts at certain times. Maybe there's another way ?? Any help with this would be awesome Thanks Quote Link to comment Share on other sites More sharing options...
paranoidx Posted January 14, 2024 Share Posted January 14, 2024 Can you do it with node Enable Solver chain under Sop Solver which have the Active feature. Add a modulo for example so you can have it repeat by frame.... Quote Link to comment Share on other sites More sharing options...
