Bouncing ray inside a curve
AntoineSfx
I'm trying to bounce a ray inside a curve, starting from a point with an initial vector  v@v which tells the initial direction.
I'm providing a curve and a starting point so that we can see if and when it starts to differ / exit the curve.
curve.obj
The algorithm is as follows
Starting from (0,0,0) in  direction  (0,0,-1)
Ray SOP against the curve.
reflect @v using: v@v = reflect(v@v, v@N);
repeat
It quickly gets stuck on the curve for a reason that's not clear;
The worst case scenario is when the direction is really close to the tangent of the polygon at the hit point; then it's possible that the next ray will start shooting through the curve if you use the bias option in Ray.
I mean .. it kinda solves the problem in some cases, but it opens the door to other ones.
Is there a robust solution to this ? It's not that critical, it's just for viz; but I'm curious because comp'l geometry is known to be really tricky. Probably going to end up with a collision pad
