Trigger alembic animations
21 minutes ago, Atom said:
Run over your end points and copy an animated Alembic model to each point. Populate the Frame field with an attribute value that contains the frame you wish to display.
Do you mean MOPS or native Houdini tools? How do I populate the frame field?
