ihab Posted April 27, 2007 Share Posted April 27, 2007 Hi Guys, I'm a dops noob and i'm trying to make a dops simulation where objects are shattered upon impact with one another. I downloaded the Fracture Sop from the exchange website and used it to pre-fracture my geometry. The problem is that the Fracture sop always creates groups named (obj0, obj1 ...etc) for every object it fractures. And there's multiple fractured objects in the simulation . I bring the fractured objects into the simulation as rbd fracured object. Later on when i try to extract the geometry into sops using an object merge sop i use the syntax specified in the houdini help (/obj/dopnet1:rbdobject1/Geometry) i replace the rbdobject1 with rbdfracturedobject1 as in my case but it doesn't work. if i try (/obj/dopnet1/obj*) it brings all the objects in the simulation. Is there anyway to extract each fractured object back to sops? thanks in advance. Quote Link to comment Share on other sites More sharing options...
MIguel P Posted April 27, 2007 Share Posted April 27, 2007 (edited) You have to write: /obj/dopnet1:obj*/Geometry Edited April 27, 2007 by MIguel P Quote Link to comment Share on other sites More sharing options...
rdg Posted April 27, 2007 Share Posted April 27, 2007 [quote name='MIguel P Quote Link to comment Share on other sites More sharing options...
ihab Posted April 27, 2007 Author Share Posted April 27, 2007 thanks for the reply guys, but you see the problem is if i use obj* i get all the fractured pieces of all objects. I'll give you an example. say i have a ball i ran into the fracture sop and it has 20 peices (obj 0 - 19). then i have a wall i ran into the fracture sop and it has 50 pieces (obj0-49). inside the dops simulation there's 2 objects named obj0 , obj1 ...obj19. then there's obj20-49 that belongs to the wall. so if i use obj* i end up getting all the pieces of both the ball and the wall. The problem is that the fracture sop creates the groups by itself and i have no way of renaming them. cheers Quote Link to comment Share on other sites More sharing options...
MIguel P Posted April 27, 2007 Share Posted April 27, 2007 You can create an attribute with different values for each object (ball and wall) and then in SOPs use the Delete SOP with delete by expression. Quote Link to comment Share on other sites More sharing options...
johner Posted April 27, 2007 Share Posted April 27, 2007 thanks for the reply guys,but you see the problem is if i use obj* i get all the fractured pieces of all objects. I'll give you an example. say i have a ball i ran into the fracture sop and it has 20 peices (obj 0 - 19). then i have a wall i ran into the fracture sop and it has 50 pieces (obj0-49). inside the dops simulation there's 2 objects named obj0 , obj1 ...obj19. then there's obj20-49 that belongs to the wall. so if i use obj* i end up getting all the pieces of both the ball and the wall. The problem is that the fracture sop creates the groups by itself and i have no way of renaming them. cheers You can toggle off the "Build Groups" option on the Fracture SOP, then just append a Partition SOP to build the groups yourself, named however you like. So in your case, maybe "ball_$CLASS" and "wall_$CLASS" for the Rule parameter in the respective Partition SOPs. Quote Link to comment Share on other sites More sharing options...
ihab Posted April 27, 2007 Author Share Posted April 27, 2007 @MIguel: I think this will work but it will be very intensive in cases of large amount of objects. thanks Johner. That's exactly what i've been looking for. rdg did a nice tweak to the otl where you specify a prefix for the groups created by the fracture. thank you all for the help Quote Link to comment Share on other sites More sharing options...
