What is wrong with my VEXpression?
5DNick
Dear ODForcers,
I have this inside a popcurveforce inside a DOPNET and am attempting to make each packed prim start moving (by this force) at a random time up to 50 frames (my scene starts at 1001)
float random = rand(@ptnum);
float framestart = (random * 50) + 1000;
if (@Frame < framestart) {
    airresist = 0;
else {
    airresist = 15;
Can you see what is wrong here, it doesn't seem to work?
I have left out the .hip because everything else works just not my code.
Thanks
Nick
I pasted your code into my hip file and it works. Depending on your setup, you can try
1. Use the @id attribute instead of @ptnum (in case you have particles dying).
2. make sure your time slider is in between 1000-1200
If that doesn't work you can group the particles you want to advect and then use that group in the popcurveforce. To do this:
1. popgroup DOP - set the group name to followCurve: paste this into the wex code
float random = rand(@id);
if (@Frame > framestart) ingroup = 1;
2. popcurvefirce DOP - turn on group and set it to followCurve; set air resistance to 15
Best regards,
Robert
vexFollowCurve_fix.hipFetching info...
OK! Thanks guys.
The problem was NOT my code it turned out, but that I also had a POP VOP doing something, so it therefor appeared they were still all moving from the beginning, when that curveforce was not actually acting until commanded.
Thanks anyway =)
