trippyzels Posted January 22, 2024 Share Posted January 22, 2024 Hi everyone! I need help with a pretty specific issue I have. I have a LOPS network in which I have four different flower meshes referenced from the geometry network as alembics. These four flowers are copied to points. In the copy to points SOP (inside the LOPs network) , there is a grid linked to a scatter and a noise attribute which allows the flowers to be scattered on the points of the grid. However, due to the sizes of the flowers and the amount of points scattered on the grid, the flower meshes overlap. How can I go about avoiding them overlapping? I tried multiple things to no avail. Please help ~ Quote Link to comment Share on other sites More sharing options...
paranoidx Posted January 27, 2024 Share Posted January 27, 2024 (edited) can you do relax to push each point away of each position farther in Scatter node ? (I assume you instance point from scatter node) https://www.sidefx.com/docs/houdini/nodes/sop/relax.html Edited January 27, 2024 by paranoidx Quote Link to comment Share on other sites More sharing options...
Atom Posted January 27, 2024 Share Posted January 27, 2024 There's also the alternate scatter which might help. https://www.sidefx.com/docs/houdini/nodes/sop/scatteralign.html Otherwise, you may have to conduct a quick deintersect simulation. Quote Link to comment Share on other sites More sharing options...
