yd5997 Posted February 27, 2024 Share Posted February 27, 2024 (edited) help... what should i do.... i can't delete shadow of geometry light... it's possible when i work in mantra... like a shadow mask can i delete this shadow in solaris karma either?? Edited February 27, 2024 by yd5997 Quote Link to comment Share on other sites More sharing options...
TobyGaines Posted May 26, 2024 Share Posted May 26, 2024 I would try the Render Geometry Settings node, you can set the shadows flag off in there... but if it's a light, it may not help :/ I have the same problem with Arnold's lights, it sucks bigtime Quote Link to comment Share on other sites More sharing options...
TobyGaines Posted May 26, 2024 Share Posted May 26, 2024 Ok yes it's in the same Render Geometry Settings node, just put " -shadow " in the Render Visibility field. I'm so glad sidefx is still more dependable Arnold. But it might be cooler to keep the shadow and instead give the geo transparency, and enable caustics, so the flame's 'shadow' will show like the real thing ; Quote Link to comment Share on other sites More sharing options...
