adamknauer1 Posted March 28, 2024 Share Posted March 28, 2024 (edited) Hey guys wondering if anyone can give me some ideas to tackle this effect on a heightfield: https://twitter.com/Jose_Molfino/status/1669804412569567233 The artist Jose says that it's a heightfield expanding inside a solver and a gradient field based on height is used for advection. Does anyone know how that works? How would you advect calculated values like gradient field vectors? Thank you! Edited March 28, 2024 by adamknauer1 Quote Link to comment Share on other sites More sharing options...
Librarian Posted March 28, 2024 Share Posted March 28, 2024 @adamknauer1 Try this ..gradient,divergence, curl, height and water , after when you are done in DOP, just import fields with SOP primitive properties and Play with different fileds, then check your LINK you have Nice tricks .. Have fun Quote Link to comment Share on other sites More sharing options...
adamknauer1 Posted March 28, 2024 Author Share Posted March 28, 2024 (edited) Hello, @LibrarianThank you for the help! Is this sort of how the shallow water solver works? Edited March 28, 2024 by adamknauer1 Quote Link to comment Share on other sites More sharing options...
Librarian Posted March 28, 2024 Share Posted March 28, 2024 @adamknauer1 Basically Yes , just here you have more View(somehow not complicated to see at least for me) , easy to control and you can adjust height , different PIC and various ways to manipulate fields. if you search I posted also Espresso Blend Fluid that have nice tricks.. so combining those 2 you can make Nice effects . Quote Link to comment Share on other sites More sharing options...
adamknauer1 Posted March 28, 2024 Author Share Posted March 28, 2024 @LibrarianOk I appreciate the advice here. I will take a look at that post as well!! Quote Link to comment Share on other sites More sharing options...
adamknauer1 Posted March 28, 2024 Author Share Posted March 28, 2024 @LibrarianDo you have that hipfile so I could dive in and see what's going on? Thank you! Quote Link to comment Share on other sites More sharing options...
Librarian Posted March 29, 2024 Share Posted March 29, 2024 (edited) @adamknauer1 You want to say that you don't have 30 minutes of your time to just create Dop (just Node DOP) and rewrite those codes. ccccc Adame Jabuko moja https://www.sidefx.com/forum/topic/95230/ Edited March 29, 2024 by Librarian 1 Quote Link to comment Share on other sites More sharing options...
animatrix Posted March 30, 2024 Share Posted March 30, 2024 Hi, Here is one way: 1. Compute grad using VEX in a Volume Wrangle: v@grad = volumegradient ( 0, "height", @P ); 2. Advect using Volume VOP SOP inside Solver SOP: 3. Run the simulation You can also get different results by playing with the advection vector: v@grad = volumegradient ( 0, "height", @P ); vector up = { 0, 1, 0 }; vector tangent = cross ( v@grad, up ); v@grad = tangent + v@grad; v@grad = volumegradient ( 0, "height", @P ); vector up = { 0, 1, 0 }; vector tangent = cross ( v@grad, up ); v@grad = tangent; 3 1 Quote Link to comment Share on other sites More sharing options...
adamknauer1 Posted April 1, 2024 Author Share Posted April 1, 2024 (edited) @animatrixThank you! What is the structure inside of your Solver Sop? Is there just a volume vop? Edited April 1, 2024 by adamknauer1 Quote Link to comment Share on other sites More sharing options...
animatrix Posted April 1, 2024 Share Posted April 1, 2024 5 hours ago, adamknauer1 said: @animatrixThank you! What is the structure inside of your Solver Sop? Is there just a volume vop? Yes only Volume VOP SOP. Quote Link to comment Share on other sites More sharing options...
adamknauer1 Posted April 1, 2024 Author Share Posted April 1, 2024 @animatrix hmm I'm not getting any advection results. Must be missing something I'm missing. Should I be using any of the inputs into the geometry file inputs? Quote Link to comment Share on other sites More sharing options...
Librarian Posted April 1, 2024 Share Posted April 1, 2024 https://cmolfino.gumroad.com/ Quote Link to comment Share on other sites More sharing options...
animatrix Posted April 1, 2024 Share Posted April 1, 2024 4 hours ago, adamknauer1 said: @animatrix hmm I'm not getting any advection results. Must be missing something I'm missing. Should I be using any of the inputs into the geometry file inputs? Do you have the gradient field and you use the right input in advect by volume VOP? Quote Link to comment Share on other sites More sharing options...
adamknauer1 Posted April 1, 2024 Author Share Posted April 1, 2024 @animatrixI have a gradient field, should it match the bounds of the heightfield that I am advecting? Should this "gradient" field have initial values? I am currently inputting the previous frame into the advect by volumes. Quote Link to comment Share on other sites More sharing options...
animatrix Posted April 2, 2024 Share Posted April 2, 2024 Yes if gradient is empty then it won't do anything. In my code you can see I am computing it using volume wrangle. Quote Link to comment Share on other sites More sharing options...
adamknauer1 Posted April 2, 2024 Author Share Posted April 2, 2024 @animatrixI'm confused why my setup isn't working;/ If you don't mind me asking, what is the correct input for the volume advect vop? Thanks!! Quote Link to comment Share on other sites More sharing options...
animatrix Posted April 2, 2024 Share Posted April 2, 2024 I think it would be easier if you could attach your file. Quote Link to comment Share on other sites More sharing options...
adamknauer1 Posted April 2, 2024 Author Share Posted April 2, 2024 (edited) @animatrixOk I think you're right Edited April 11, 2024 by adamknauer1 Quote Link to comment Share on other sites More sharing options...
animatrix Posted April 3, 2024 Share Posted April 3, 2024 I see the issues, you need to have the grad field the same as your height field: But most important thing is to use a non-zero Timestep value: Then it works. 1 Quote Link to comment Share on other sites More sharing options...
adamknauer1 Posted April 3, 2024 Author Share Posted April 3, 2024 @animatrixAhhhh I see. Makes sense why it wasn't working! Thanks for all your help here!!! 1 Quote Link to comment Share on other sites More sharing options...
