MadMax50 Posted April 16, 2024 Share Posted April 16, 2024 Hello I was trying to come up with a solution to inherit the attributes (specifically the name attribute) from the original geometry to the newly created faces that the boolean fracture creates . There is no option to inherit attributes like the voronoi fracture which I find very strange. This is the solution I came up with... . If anyone has a better solution please let me know. I attached a hipfile and a screenshot. Basically, its just an attribute transfer from the original geo to the cuttter before the boolean... however I feel like this may not the best solution for a more complex situation..... hopefully someone can give there input on this. Thank you boolean_inherit_attribuets_solution.hip Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted April 17, 2024 Share Posted April 17, 2024 Hi, you can use attribute promote sop for this boolean_inherit_attribuets_solution_01.hipnc 1 Quote Link to comment Share on other sites More sharing options...
MadMax50 Posted April 17, 2024 Author Share Posted April 17, 2024 @vicvvshThank you, that makes sense. I didnt know about the "piece Attribute" parameter on the promote sop. Quote Link to comment Share on other sites More sharing options...
