Backticks Inside Backticks
kubabuk
Guys, I'm trying to dynamically create the following command
opparm /out/test -v -p eframe ( `ch("../../img/all/all/f1")` )
to do that I using stringcat expression
opparm /out/test -v -p eframe ( `strcat(strcat("ch\(\"../..",chs("rop")),"\/f1\"\)")` )
But I get an error because it is not possible to have double back ticks. The problem is that I need one set of them otherwise my expression will not be evaluated. So the following doesn't work:
`strcat(strcat("\`ch\(\"../..",chs("rop")),"\/f1\"\)\`")`
simpler test doesn't work as well
echo `strcat("\`","test\`")`
Do you have any idea?
PS. probably answer is again pretty simple :)
thanks
kuba
Hi there,
The easiest solution is to break your break your command into two (and use varaibles).
So, first stash the evaluation of your deepest expression in a variable, and then use the variable in the our expression. Know what I mean?
set tmpvar = `firstexpression()`
`secondexpression( $tmpvar )`
- and thus avoid nested expressions:)
:thumbsup:
we should setup some game on it! Who will write more aesthetically pleasing piece of WORKING code
quite nice attempt Kuba!
:oneeyedsmiley02:
Edited by SYmek
:thumbsup:
:oneeyedsmiley02:
That's a "side effect" of my recent work :rolleyes: - definitely too much awk stuff recently
