Message passing aggghhhrrrr
AndrewVK
Could anybody explain me what wrong have i done while translating from SL
into VEX shaders, which use message passing?:unsure:
In VEX there seems to be no message passing at all :o
RenderMan SL
light
messagetest(
float intensity = 1;
color lightcolor = 1;
color test = (1,0,0);
point from = point "shader" (0,0,0);
float atten = 1.E6;
illuminate(from)
Cl = (intensity * atten / (atten + sqrt(L.L))) * lightcolor;
surface test()
color test;
color Clr;
normal Nn;
vector Ln;
Nn = faceforward(normalize(N),I);
Clr = 0;
illuminance( P, Nn, PI) {
if (lightsource("test",test)==1){
Ln = normalize( L );
Clr += test * Ln.Nn;
}else{
Clr += Cl * Ln.Nn;
Ci = Clr;
VEX
light
messagetest(
vector lightcolor = 1;
vector test = {1,0,0};
float atten = 1.E6;
Cl = (intensity * atten) / (atten + length(L)) * lightcolor;
#include <math.h>
surface test()
vector test;
vector Clr;
vector Nn;
vector Ln;
Nn = frontface(normalize( N ),I);
Clr = 0;
illuminance( P, Nn, M_PI) {
if (limport ("test",test)==1){
Clr += test * dot(Ln,Nn);
}else{
Clr += Cl * dot(Ln,Nn);
Cf = Clr;
Hey Andrew,
How've you been? It's been a while since I converted your Stained Glass shader. :)
To answer your question, VEX does message passing.
From your code:
light
messagetest(
float atten = 1.E6;
Just do this:
export vector test = {1,0,0};
Now, your geometry will be shaded red. B)
For VEX, you have to specify which parameter is to be exported(message passing).
Thank You Steven!!!!!!!!!!!
Finally i`ve begun to study VEX.
"export" works,workS,worKS,wrRKS,wORKS,WORKS!!!:D :D :D :D :D :D
It`s definitely strange this "magic word" can`t be found in the doc.
.....time to finish optimized volume spotlight shader:)
  • 3 weeks later...
Hey Steven!
I need some help whith this shader!!!
My english is probably bad...so please be patient.
Ok...basic idea:
1.Get some info from light(s) (position,direction,coneangle,conelength)
2.Test current ray for intersection with current lights cone.
3.If inersection occurs then perform raymarcher from IN point to OUT point
if no...then do nothing.
I`m not math guru...so i just pick up "Line_vs_Cone" equation from inet.
It works fine but solves phantom cone too :(
The question is how to kill phantom?:ph34r:
I try:
if (dot(lightdirection,(inersectionpoint-lightorigin)) >= 0)
...but it doesnt work correctly. And i cant understand WHY.:blink:
Can You explain me whats wrong?:unsure:
http://andrewvk107.narod.ru/RayBox/Phantom.jpg (rmb, save target as)
http://andrewvk107.narod.ru/RayBox/shaders.zip (rmb, save target as)
Hey Andrew,
I'll try to understand the raycone() function first then I'll see what I can do. Also I'm not too knowledgable with VEX or shading writing so I'll probably not able to help you much.
Have you tried using the light direction, Lz, to control calculation of the raycone()?
There is a pdf file called "vex_theory.pdf" available for download from SideFX site in the Rendering section.
In that file there is some info about message passing between shaders in VEX.
Not a lot of it, just one page but still... maybe you will find it usefull.
