doc Posted May 31, 2007 Share Posted May 31, 2007 Hi, I seem to be having a little trouble with my deeps shadows, for some reason it's making my object look super "spotty" (see image). I've tried playing with the Compression z-bias (values between -1 and 1) but that doesn't seem to help. I've attached and image and my hip file. Thanks in advance L shadow_issue_v1.hip Quote Link to comment Share on other sites More sharing options...
Jason Posted May 31, 2007 Share Posted May 31, 2007 Try raising your Shadow Bias and/or turning on Z-Depth Motion Blur. Quote Link to comment Share on other sites More sharing options...
doc Posted June 1, 2007 Author Share Posted June 1, 2007 Try raising your Shadow Bias and/or turning on Z-Depth Motion Blur. Yeah, already tried adjusting the Compression z-bias doesn't seem to help. Quote Link to comment Share on other sites More sharing options...
doc Posted June 1, 2007 Author Share Posted June 1, 2007 Fixed the issue by upping the Z-depth samples. 6x6 seem to do the trick. L Quote Link to comment Share on other sites More sharing options...
Jason Posted June 2, 2007 Share Posted June 2, 2007 Yeah, already tried adjusting the Compression z-bias doesn't seem to help. I'm talking about Shadow Bias, not Compression z-bias. Quote Link to comment Share on other sites More sharing options...
bandit Posted June 3, 2007 Share Posted June 3, 2007 and it would be great,if someone give a clue how to get a shadow only pass on that. Quote Link to comment Share on other sites More sharing options...
Bernard Posted June 3, 2007 Share Posted June 3, 2007 Hello Bandit, just studying your hip file a little bit... I have a few questions: what does the extension mean in the 'shadow.dshad' file ?(dshad) and what does 'exr' mean in the output picture and 'openexr' in the Image Device (Renderman ROP) ? Is it not needed in Houdini to create Renderman light shaders to render a scene? I hope it's not to many questions... many thanks, bern Quote Link to comment Share on other sites More sharing options...
Jason Posted June 3, 2007 Share Posted June 3, 2007 and it would be great,if someone give a clue how to get a shadow only pass on that. Using a ShadowMatte Shader will provide you a shadow only (look in the Alpha channel, as the RGB is the color of the shadow - which is usually black) Quote Link to comment Share on other sites More sharing options...
bandit Posted June 4, 2007 Share Posted June 4, 2007 thank you so much jason. and bernard i suppose,you should shoot your question to doc. i wish i could have answered those though. Quote Link to comment Share on other sites More sharing options...
bandit Posted June 4, 2007 Share Posted June 4, 2007 hi jason. that was the point i stucked once. shadow matte is just fine with mantra. what is the equivalant for renderman. the onlything logical is r_matte, but could't make it work. thank you. Quote Link to comment Share on other sites More sharing options...
