shirak Posted June 11, 2024 Share Posted June 11, 2024 I delete @shop_materialpath it keeps reappearing. That file path is definitely the path of the pyrosolver that I created. Where on earth is it stored and why is it being resurrected? I think I was able to delete it off before, but I don't know how... vdb_attri.hip Quote Link to comment Share on other sites More sharing options...
tamagochy Posted June 11, 2024 Share Posted June 11, 2024 On pyrosolver look tab disable assign material Quote Link to comment Share on other sites More sharing options...
shirak Posted June 12, 2024 Author Share Posted June 12, 2024 @tamagochy Hi! I am always grateful for your help. What if I don't want to run the pyrosolver again? Loading VDB as proxy and reassigning materials worked fine when rendering with Arnold, but I'm having trouble testing Redshift. I'm also confused by the fact that this attribute is not visible in Houdini but still comes back. Quote Link to comment Share on other sites More sharing options...
tamagochy Posted June 12, 2024 Share Posted June 12, 2024 I checked your scene, I dont know what problem you have with RS, but you havent any material on VDB after delete shop_materialpath. Looks like its not VDB problem but RS setup Quote Link to comment Share on other sites More sharing options...
shirak Posted June 13, 2024 Author Share Posted June 13, 2024 Thank you checking my file. Can you delete @shop_materialpath? After delete, write fileCache as vdb,attribute reappears on my hip.. I found that just adding vdb_resample it happens. Quote Link to comment Share on other sites More sharing options...
tamagochy Posted June 13, 2024 Share Posted June 13, 2024 Just remove it after all manipulations with VDB Quote Link to comment Share on other sites More sharing options...
shirak Posted June 17, 2024 Author Share Posted June 17, 2024 I asked SESI and they said it was a bug. Thank you for your time. Quote Link to comment Share on other sites More sharing options...
