Adding Scripts To Rmb Click-menu
B.Walters
Look for this file
$HOUDINI_PATH/houdini/OPmenu
Does anybody know how I can add my own script to the menu you get when you right-click a node?
I've seen it done before... I just haven't been able to figure out how.
  • 3 years later...
It is possible to use a Python script from OPmenu with a little trickery. The following is an example for performing an action on a digital asset from a class I taught at SESI LA over the summer. The hscript file it calls just executes a python -c call that imports and reloads a module, then calls a function from it passing in the node path.
OPmenu entry:
'Expr: execute("otgetotl -b $opmenu_optype")' debugOTL "Debug OTL" debug.hsc
debus.hsc:
set script = $arg0
set node = $arg1
python -c "import opmenu_wrapper; reload(opmenu_wrapper); opmenu_wrapper.debug('$node');"
Hopefully one day OPmenu will be replaced by an easy to use xml system just like the main menus and parameter versions.
Edited by graham
