Help! it seems shadow and gradiance of color didn't come out in rendered textures!
I figured out why ...
There is something called headlight in the viewport and that contributes a default light source with a specefic direction.
But the render view only affected by the light source node I create, usually with a totally different direction and that leads to a different result.
If I want the same light as the default headlight, I can go to mantra's objects tab to enable Headlight creation option.
Tha's it.  Down!
