cellchuk Posted June 21, 2007 Share Posted June 21, 2007 (edited) Hi all, I just wanted to share some of my tests with L-Systems that I have done earlier My aim was trying to get different effects with L-Systems I will be posting the other ones in these days as well Here is the first animation test : Cubes It is kind of overlapping but just a matter of time to improve it (which I don't have at the moment ) Thanx. -------------------- EDIT: The links has changed. you can check the l-sys videos through my web-site now. thanks. http://www.selcukergen.net/proj_lsys.html Edited February 4, 2008 by cellchuk Quote Link to comment Share on other sites More sharing options...
rdg Posted June 22, 2007 Share Posted June 22, 2007 It is kind of overlapping but just a matter of time to improve it (which I don't have at the moment ) cool! Somebody told me that L-System create changing point number - obviously - an therefor don't support motionblur. But your example is mblurred. How's that? Georg Quote Link to comment Share on other sites More sharing options...
psychojay Posted June 22, 2007 Share Posted June 22, 2007 gr8 stuff man.....can u plz post a sample file which can be very helpful to ppl like us who are new to houdini...... Quote Link to comment Share on other sites More sharing options...
old school Posted June 22, 2007 Share Posted June 22, 2007 Somebody told me that L-System create changing point number - obviously - an therefor don't support motionblur.But your example is mblurred. How's that? I always love it when people lovingly speak in absolutes. That pretty much sucks the wind right out of me... You can send anything in to motion blur. It may fail but you can always try and then hammer out some solution. For this specific example, deformation blur will work except on those frames where the branches end and new branches start = point count change across the camera shutter. You can't tell in this example because those frames _shouldn't_ motion blur and it is very symmetrical. As long as the lsystem can keep the same point count for the current frame and the shutter time offset, then you will get motion blur. Goes for any geometry. I can see some l-system rules doing this as long as your shutter time doesn't span frames. It will also help when we can shift the motion blur to a positive offset in H9. That will make most generated lsystem geometry able to motion blur on all frames. Fyi you can visualize this by changing the playbar to non-integer and scrub at the sub-frame level to see exactly when the point count changes. And if that doesn't work, you can always try to build in a velocity vector in to your lsystems rules or some other way and use velocity based motion blur... Quote Link to comment Share on other sites More sharing options...
cellchuk Posted June 22, 2007 Author Share Posted June 22, 2007 (edited) Thanx. I think "old school"s explanations will be enough for the point count and the motion blur questions. I have used deformation type motion blur in this example. And I am gonna try to send the .hip file as soon as possible for people who are interested. Thanx. Edited June 22, 2007 by cellchuk Quote Link to comment Share on other sites More sharing options...
Nico D. Posted June 22, 2007 Share Posted June 22, 2007 Very nice ! I love how it construct itself. Could be good to see those formulas ! Quote Link to comment Share on other sites More sharing options...
cellchuk Posted June 22, 2007 Author Share Posted June 22, 2007 Very nice !I love how it construct itself. Could be good to see those formulas ! Thanx gaucho, I am going to post the formulas when I put the other animations as well. "but I need to tidy my desktop up first to find the .hip's" cheers Quote Link to comment Share on other sites More sharing options...
cellchuk Posted June 22, 2007 Author Share Posted June 22, 2007 (edited) Hi, Here is the .hip file for the first cubes example. I will post the second cube example soon which doesn't overlaps. Edited June 24, 2007 by cellchuk Quote Link to comment Share on other sites More sharing options...
cellchuk Posted June 22, 2007 Author Share Posted June 22, 2007 (edited) This is the second version of the cube animation This has a different behaviour which dosn't overlaps [but I'm not sure ] Cubes_v2.mov Edited June 22, 2007 by cellchuk Quote Link to comment Share on other sites More sharing options...
cellchuk Posted June 23, 2007 Author Share Posted June 23, 2007 new posts will be on this link http://forums.odforce.net/index.php?showtopic=5508 Quote Link to comment Share on other sites More sharing options...
