Prot Fur Sop
Hi all!
this morning i started to check out the proto fur SOP for Houdini 8.1;
i found a great resource on side effects forum done by Wolfwood;
i downloaded his file and everything seems clear.
But, when i started creating a different network to simply put fur on a grid
i get a permanent error on the fur sop; i tried to get the same attributes, i copied and pasted the original nodes,
under the same object node, in the same file provided by Wolfwood, and nothing.
Does anybody can help me to figure out what is going on?
Thanks!
Andrea
furball_150_mod.rar
I know that SESI, around 8.1.711 or something, released a new version of the Fur tools which broke some of Wolfwoods earlier examples. Which version are you running? I thought that he updated his examples for the newer version so I'll bet that you just have a mismatch in versions. Download the latest 8.2 and find the latest archive in Wolfwoods thread and try again perhaps?
Thanks a lot!
I removed the scatter from the guides network and it works perfectly, interesting!
At the moment I'm running the 8.1.874 version, I still did not try the 8.2 version, i will do it soon :-)
I was also wandering, wath are the "must have" attributes to make fur works?
in the Wolfwood file i can list the following:
for Guides:
. point attributes:
uv
Cd
width
for rest skin geometry:
. point attributes:
N
up
rotation
furdensity
furangle
furkink
furrandomscale
. vertex attributes
uv
. primitive attributes
area
for the clump geometry:
. vertex attributes
uv
clumppercent
clumporigin
clumpradius
Are all those attributes all strictly necesserary, and of the same type
(for example, the uv are vertex attributes instead of point attributes)?
then there is a detail attribute common to every branch of the network: varmap.
is this created automatically by Houdini?
Thanks a lot for the help!
Andrea
Hiya!
I remember if you run the proto_install again (in 8.2), try to find the SOP_Fur.inst in the list (if I am not mistaken after you've installed it it appears on a list to the right, so you may need to scroll up to find it) - if you read the readme there is a detailed descripton on what attributes are read by the fur sop.
GW
i found out the read-me file and we can say that the attributes needed are:
for Guides:
-Cd
-width
-> for what I see those are not mandatory for the fur it-self, but fundamentals to render lines
-furdensity
-furangle
-furkink
-furrandomscale
-clumppercent
-clumporigin
-clumpradius
Thanks!
and see you soon with some furry images :-)
A.
oh yes, you are right!
the clumping attributes in the Wolfwood file are vertex and primitive attributes:
so, for the clump geometry:
. vertex attributes
clumppercent
clumporigin
clumpradius
all the other (for rest and guide geometry) seem to be point attributes
Cheers!
Andrea
Hello!
i applied fur on a character I did 3 years ago, and i got these results;
http://www.3dartist.it/wip/jaw_05_A.jpg
http://www.3dartist.it/wip/jaw_05_B.jpg
I used 3 points lights casting Z-depth shadows;
the color of the fur is done in the sop network;
so I just applied a simple lighting model shader, and on the
diffuse, i plugged the color took from the sop network.
But,
when i started lighting, i had some weird problems;
it seems that the shading was exactly at the opposite side of where it should be;
so i just did a simple normal pass, and i got these results:
http://www.3dartist.it/wip/jaw_06_normal_fur.jpg
and i think I have a problem;
the fur seems not to have any normal value;
is it correct? or I should have a different result?
I think I'm missing something
Any suggestion is more than welcome!
Thanks!
Andrea
p.s.: I'm using the proto fur sop for Houdini 8.1
Hello!
But,
Curves are rendered as thin flat planes that are oriented toward camera. Because of this all the normals will be facing the camera which makes it difficult to light when using the standard lighting models. Have a look at the VEX Hair SHOP.
As for your other question, the reason why your normal pass doesn't look too exciting is because N wasn't normalized before the Shift Range VOP.
Great!
thanks a lot
now I see, I tought fur was redered as a geometry during render time;
Now I'll dive into both the hair shader and the hair VOPs node;
I'm doing the first test and it's working fine :-)
Thanks!
Andrea
The Fur Procedurals spawns tons and tons of curve geometries which are considered to be a "light-weight" geometry primitive. It is possible to attach a orient vector attribute to your curves. Instead of the curve facing the camera it will face in the direction of the orient attribute (in object space).
Left curve has a width of .1, right curve has a width of .1 and a varying orient attribute.
Edited by Wolfwood
Hi!
sorry for the delay, busy days!
really interesting and I have some questions :-)
so, the rot attribute you created in your ball scene is the orient one?
I tried to rename it and it orients all the fur guides of the fur;
the orient attribute is a quaternion, so 4 dimensions attribute;
what is the best way to define it?
I saw you used the function matrixtoquad, is it a common workflow or a specific need for that scene?
to do the changing of the orientation in your last images did you set up the orient attribute as a point attribute?
Thanks a lot!
Andrea
p.s.: i fixed the normal pass, yes i did not normalized:-) !
The rot attribute is independent of the 'orient' one. The rot attribute is a float 4 (quaternion) that I used to rotate the guide hairs to the surface. (The Copy SOP makes use of the 'rot' attribute)
Take a look at this thread, http://www.sidefx.com/index.php?option=com...opic&t=6679
There are two 'orient' attributes in Houdini. The float4 (quaternion) orient attribute is used by the Copy SOP and Instancing. There is also a float3 (vector) version of 'orient' which is used for curve rendering. In the above image I used the vector version.
Using the 'rot' or 'orient' (float4) to rotate objects in conjunction with the Copy SOP is something that I personally like to do. (Using fur doesn't require those attributes.) Some people like to use the 'N' and 'up' vector attributes instead.
Thanks a lot!
Setting the 'orient' (vector) attribute works as either point or vertex attribute. However you need to use the latest version of Houdini for it to work. When the Fur Procedural dumps out geometry it automatically converts all Guide hair attributes to vertex attributes. Up until recently mantra only recognized a point version of the orient attribute.
I apolgize for a lack of documentation in the hip file. It was meant more as reference than as a tutorial. :unsure:
Edited by Wolfwood
Hi!
sorry for the delay!
busy days :blink:
thanks a lot for all the informations, really clear and useful! i saved the post :-)
reading the other thread, i understood why you used the rot attribute;
looking at the help i did not found it, so I thought it was a substitute of the orient one;
i also finished my first attempt using fur
www.3dartist.it/wip/jaw_comp_02.0169.jpg
www.3dartist.it/wip/jaw_comp_02.mov
i attached and painted (randomly) the fur;
i just rendered out a little sequence (sorry for the animation, i did it 3 years ago, and it sucks :( )
it was just to render moving fur and see how much it flickers etc..
i used pretty high sampling values (6 6)
thanks for the help
Cheers!
Andrea
