revelationsr Posted September 16, 2024 Share Posted September 16, 2024 Hello. I have a point system and on that system I have distributed an attribute called size. It is a number range that is between 0 and 1. I have about 100 stones that I would like to copy to those points. These stones are all different sizes and I ran them through a "measure" sop to get their size. So they also now have an attribute called size ranging from 0 -1. What I would like is for the "copy to point" to read the size attribute on the points and then select a stone based on its size that is the closest match. Then copy that stone to that point. This way I can have control over where the patches of larger stones will congregate. Thank you for your time. Quote Link to comment Share on other sites More sharing options...
hannes603 Posted September 16, 2024 Share Posted September 16, 2024 untitled.hip use the variant attrib in copy to points.. super simple Quote Link to comment Share on other sites More sharing options...
revelationsr Posted September 16, 2024 Author Share Posted September 16, 2024 O so it needs to be all integers. Ok then I will convert it then hopefully it will work. Thank you for your time 1 Quote Link to comment Share on other sites More sharing options...
