davidyannick Posted September 28, 2024 Share Posted September 28, 2024 I'm trying to texture a ball with position but when the ball moves the gradient moves too, I've tried with rest with the same issue, can you help me please ? I use Houdini 20.5.370 and Karma CPU Thanks Here is my process ; Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted September 28, 2024 Share Posted September 28, 2024 Hi, with rest it should work. Read rest attribute with Mtlx Geometry Property Value VOP and use it instead Mtlx Position VOP. Quote Link to comment Share on other sites More sharing options...
davidyannick Posted September 29, 2024 Author Share Posted September 29, 2024 18 hours ago, vicvvsh said: Hi, with rest it should work. Read rest attribute with Mtlx Geometry Property Value VOP and use it instead Mtlx Position VOP. Thanks for your help I had put a transform node before the rest - I'm dumb Quote Link to comment Share on other sites More sharing options...
