GlennimusPrime Posted October 1, 2024 Share Posted October 1, 2024 (edited) Hi there, I'm building an ocean starting with the large ocean shelf preset. I only seem to get wave detail close to the camera. Further out toward the horizon I lose displacement detail. Should this be active displacement back there, or should I be seeing bump? Just a quick low quality render for now. The top half of the image seems to lose detail. The sky begins to reflect like a mirror. Note: Our studio is currently limited to Houdini 19.5.493 so I don't have access to the Ocean Procedural LOP. This setup is using the slightly older Karma Ocean LOP I am unable to attach a scene file due to work limitations, but happy to answer any questions. Edited October 2, 2024 by GlennimusPrime Quote Link to comment Share on other sites More sharing options...
GlennimusPrime Posted October 2, 2024 Author Share Posted October 2, 2024 It seems by default, even with the correct render geometry set on the Karma Ocean LOP, it still uses the proxy geo - which had more tessellation closer to camera, which explains the detail loss on the horizon. I unchecked use proxy geo and things seem better. 1 Quote Link to comment Share on other sites More sharing options...
hannes603 Posted October 2, 2024 Share Posted October 2, 2024 looking already like a good startingpoint! Quote Link to comment Share on other sites More sharing options...
Atharv59 Posted November 18, 2024 Share Posted November 18, 2024 (edited) Hi, I'm working on creating an ocean starting with the large ocean shelf preset. I’m noticing that I only get wave detail close to the camera, while the displacement detail fades out toward the horizon. Should I be using active displacement for that distant area, or would it be better to use bump mapping? This is just a quick, low-quality render for now, but I’ve observed that the top half of the image loses detail, and the sky starts to reflect like a mirror. Any insights? Edited December 13, 2025 by Atharv59 Quote Link to comment Share on other sites More sharing options...
GlennimusPrime Posted November 27, 2024 Author Share Posted November 27, 2024 On 11/19/2024 at 3:58 AM, Atharv59 said: Hi, I'm working on creating an ocean starting with the large ocean shelf preset. I’m noticing that I only get wave detail close to the camera, while the displacement detail fades out toward the horizon. Should I be using active displacement for that distant area, or would it be better to use bump mapping? This is just a quick, low-quality render for now, but I’ve observed that the top half of the image loses detail, and the sky starts to reflect like a mirror. Any insights? I think I solved the same issue by increasing the Dicing Quality Scale in Karma Render Settings. Quote Link to comment Share on other sites More sharing options...
Zakariya Posted September 7, 2025 Share Posted September 7, 2025 Hi, I’m setting up an ocean using the Large Ocean Shelf preset. I’ve noticed that the wave detail looks good near the camera, but the displacement gradually fades out toward the horizon. Would it make more sense to use active displacement for the distant areas, or would a bump map be more appropriate? This is just a quick, low-quality render for now, but I can see that the top half of the image loses detail, and the sky starts reflecting almost like a mirror. Any advice would be appreciated! Quote Link to comment Share on other sites More sharing options...
Niltonn22 Posted January 9 Share Posted January 9 On 9/7/2025 at 7:11 PM, Zakariya said: Hi, I’m setting up an ocean using the Large Ocean Shelf preset. I’ve noticed that the wave detail looks good near the camera, but the displacement gradually fades out toward the horizon. Would it make more sense to use active displacement for the distant areas, or would a bump map be more appropriate? This is just a quick, low-quality render for now, but I can see that the top half of the image loses detail, and the sky starts reflecting almost like a mirror. Any advice would be appreciated! For distant ocean areas, it’s usually better to fade out true displacement and rely on a bump or normal map. Active displacement far from the camera adds cost without visible benefit. Using a bump map preserves wave detail, prevents overly smooth mirror-like reflections, and keeps the horizon looking more natural while remaining render-efficient. Quote Link to comment Share on other sites More sharing options...
